Austro Engine successfully tests rotary engine
Diamond Aircraft announced that on 8 January the AE80R engine successfully performed on the Austro Engine test bench.
The engine which has been in development for two and a half years will have a final target weight of 27kg with an output of 80hp (58kw). According to Diamond, compared to the AE50R (55 PS Austro Engine rotary engine) the new engine has no loss lubrication system anymore which results in an extremely low oil consumption. A dual FADEC (Full Authority Digital Engine Control) controlled fuel injection system will keep fuel consumption on the lowest possible level. The engine is designed to power small manned or unmanned aircraft.
According to Christian Dries, Chairman and Owner Diamond Aircraft, the AE80R might has the potential to become one of the leader in the extremely weight sensitive market of LSA (Light Sport Aircraft) and ultra-light aircraft. “The engine has no vibration and therefore it is ideal to power UAVs (Unmanned Aerial Vehicles) with highly sensitive equipment,” he added.
<a href=’http://www.diamond-air.at’ target=’_blank’>www.diamond-air.at</a>
