15 October 2019
The absurd design of some parts of UK airspace has been highlighted by the CAA itself in its latest update on infringement hotspots – in this case, Bagshot in Surrey.
The CAA says it “has noticed a recent increase in airspace infringements in the southwestern corner of the London Control Zone (CTR) where pilots are navigating using the navigation features in the vicinity of Bagshot.”
And which navigation features might they be?
In its wisdom, the CAA has designated both the town of Bagshot and the nearly adjacent junction with the M3 motorway as Visual Reference Points (VRPs). Both are in the London CTR, which is Class D airspace at this point, and 6nm south of the final approach track to Runway 09R at London Heathrow Airport.
It has to be said that Bagshot is not easily distinguishable from the air – it’s just another cluster of buildings in a fairly built-up region. However, the more easily spotted 765ft radio mast a bit further southwest of Bagshot is NOT a VRP. More importantly, it does lie outside the CTR – by a mere 300 metres. See top photo which can be viewed larger here.
So the CAA’s advice is, “Pilots not in receipt of a clearance to enter the London CTR should maintain a track to the west or southwest of the mast.”
Note: do not fly over either of the official annotated VRPs on the CAA’s own 1:500,000 chart – Bagshot town or Junction 3 on the M3 – because that’s an airspace bust unless you have a clearance.
The CAA carries on: “To prevent an airspace infringement, as part of pre-flight planning and in-flight execution, pilots are strongly encouraged to:
Of course, the CAA could always designate the TV mast as a VRP.
* Take 2: remain 200ft from the base of controlled airspace and/or and 2nm from edge of any airspace.
3 comments
If the problem is VFR referencing, why doesn’t the CAA border the London CTR using motorways (M25 being the most obvious answer). Those roads are unmistakable from the air. Would make everyone’s lives a lot easier.
Bagshot is a Village not a town. Please amend your post.
Recognising that the key point here is clearly that Bagshot is in fact a village not a town(!), as a local flyer, the Bagshot mast is the visual feature I use to ensure I stay out of the Heathrow zone. I can see the two VRPs would be useful to anyone either entering or leaving the zone and in receipt of a service, but is the apparent contradiction of them being in rather than out not helpful? Perhaps making the mast a VRP and dropping one of the others, given they are so close to each other anyway, would make more sense. I wouldn’t support making the M25 the zone limit, its way too useful as a visual navigation feature in what is already confined airspace between Heathrow and Gatwick, and likely to become even more so if TAG Farnborough gets its way.
