As Chief Flying Instructor for Aerobility for 15 years, Mike Owen has plenty of experience handling all sorts of passengers. Here are his top tips for briefings
4 June 2024
Part of the fun of flying is sharing your passion with passengers and you, as captain, have a legal responsibility* for the safety of your passengers and must brief them. Ideally, the briefing will start before they get anywhere near the aircraft and you can encapsulate all the required and advisory safety points across a set of briefings.
Here are some ideas how you could tailor the contents of a set of appropriate briefings for your passengers depending what stage of the flight you are at. The briefings do not have to be to a rigid formula and are often in the form of help.
If you do not know your passengers, then introduce yourself and explain what the flight will involve, such as, where you are going and what to expect your passengers could see. If going abroad, check everyone has their passports!
Express how safety is a priority and taken seriously in General Aviation. Depending on the airfield, they may need to wear a high visibility jacket when airside.
If the flight is over the sea (definitely if beyond glide distance from land), they will need to wear life jackets. Help them put the life jackets on and show how the jackets would be inflated if they were in the water. Stress that they must not operate their jacket inside the aircraft as it would stop them exiting the aircraft.
If you are carrying a dinghy then cover the operation of the dinghy – including retrieval, clearing the aircraft and inflation.
Moving on, cover the importance of look-out and encourage reporting any sighting of other aircraft. Describe the clock code and give some examples.
Before you get near the aircraft describe how your passengers should behave on the airfield. Stress the dangers of propellers and aircraft. Ensure that passengers are aware that they cannot just wander around on the airfield and should accompany you to your aircraft.
When you approach your aircraft ensure the passengers approach from the back and avoid going near the propeller. Be aware if they get their phones out to start taking photos as they will usually gather by the front of the aircraft.
In summary, my suggested toolkit of safety briefing points given before going airside could include:
If flying over the sea:
Let’s get out to the aircraft and fly.
Any baggage should be secured inside the baggage compartment unless very small items.
Demonstrate how to get into the aircraft, open the door and use the seats. For example, on a PA28 there is only one door and the passengers have to step onto the wing walk area and then get down into the aircraft.
Potential risks here are:
Once everyone is seated inside the aircraft give the following briefing points:
When everyone is fastened in, the aircraft is started and headsets are on, do a communications check to make sure you can hear everyone. This is very important as your passengers can help with aircraft traffic spotting and reporting – or letting you know if they feel ill.
You can now give a summary of the flight and the importance of not touching the controls and using seat belts.
We can summarise this as your Captain’s briefing including:
Between the run up area and the hold is a good time to give the emergency briefing (or some form of it) to remind yourself and the passengers what could happen in the unlikely event of an emergency on take-off:
Please ensure you, as pilot-in-command, are familiar with your emergency procedures if there are any engine or aircraft issues after departure, especially if they may involve a forced landing without power. It is something that I rehearse with pilots on a checkout flight as you never know when you may need it (hopefully never!).
During the flight encourage your passengers to report any air traffic to you and to ask questions when you are not talking to air traffic services. Point out any interesting sites or ground features. When you are nearing your destination airfield ask everyone to be quiet during this phase as it is likely to be busy on the radio.
After landing and shutdown it is time to help your passengers exit the aircraft and get them safely back off the airfield. Post flight, gather headsets and lifejackets (if used), stow them and secure the aircraft.
Then it is time to enjoy a drink and maybe a meal – depending on your plans and the destination. It’s a great time to relive the flight and answer questions.
*CAA Safety Sense leaflet 02: “It is a legal requirement under the Air Navigation Order (non-Part-21 aircraft) and Air Operations Regulation (Part-21 aircraft) that the pilot in command brief passengers on the safety and emergency procedures relevant to the flight.”
