7 April 2020
The first of Flight Design’s new F2 aircraft has arrived in the USA. The F2 is a clean-sheet design and will be produced alongside Flight Design’s existing and popular CT series.
The F2 will be produced in several versions – and eventually stretched to make a four-seater, the F4. The first model is the F2 LSA, pictured above, which has passed the required ASTM compliance tests and will be available in the US in the 600kg Light Sport Aircraft category.
Top is the photo Flight Design has released of its latest aircraft, the F2. Above is the cockpit which is bigger than the CT’s. The F2 will be made in several versions to meet different classes and also with 100% electric propulsion by December 2021
Other news that German light aircraft manufacturer Flight Design intended to reveal at the now-cancelled AERO Friedrichshafen show includes:
The new look Flight Design CT with aero tweaks, particularly to the cowling, gear leg and spinner, to reduce drag
The CTLS 2020
Flight Design says the CTLS 2020 is a combination of the proven CTLS with technical and aerodynamical upgrades and a new exterior and interior look.
The cowling is reshaped and longer with an integrated landing light and an additional NACA inlet to improve heating. There’s also a new landing gear leg with internal break lines and new wheel fairings. The result is reduced drag and an increased max speed.
Hard to believe this is the cockpit of a two-seat LSA! It’s the 2020 Flight Design CTLS with all-Garmin avionics
Avionics are now all Garmin with a G3X glass cockpit, GMC 507 autopilot with pilot assistant functions, GMA 245 audio panel with USB charging port and Bluetooth connection.
From 1 March 2020, Flight Design is offsetting carbon emissions from the fuel used by its aircraft powered by the Rotax 912 iS Sport engine for the first 2000 hours of operation.
It looks good but I still love my CTSW
