13 June 2017
It seems a no-brainer really: many pilots would love a Cirrus SR22 or a Cessna TTx, fast, sleek, high-performance four-seaters but both have a mega price tag.
So for kitplane makers Lancair, now under new management, Mark and Conrad Huffstutler, the gap in the market is an aircraft that’s just as good but at about half the cost. Hence, the Lancair Mako.
Lancair says the Mako kitplane will be launched at this July’s EAA AirVenture (Oshkosh to you and me) but it has slipped out some early info. They’ve locked onto several key points:
Lancair Builder Assist
Cut a year off the build time with the factory Builder Assist Programme which not only helps ‘jump-start’ builders but also teaches proper composite skills, and provides technical assistance in the crucial early stages.
To further speed up the build, Lancair also offers a fast-build firewall forward option. That means the engine is installed on its mount, complete with all baffling, hoses, prop governor, and other necessities. Lancair claims the engine can be mounted and fully plumbed in less than a day using this option.
