9 March 2018
The latest version of the Slovakian Dynamic WT9 in light sport aircraft (LSA) spec is to be imported by new UK agent, LX Aviation.
The aircraft has been certified as an LSA by EASA and will cost €154,000 plus VAT and delivery. The cost includes full equipment, instrumentation with glass cockpit, and ballistic parachute.
LX Aviation is an offshoot of LX Avionics based at Turweston. A demonstrator aircraft will arrive in the UK in May and will tour the country, incouding trade shows, and offer test flights.
Two kit versions of the Dynamic are also proposed. The first is the WT9 with similar weight limit of 600kg. The second is the Advantic WT10, a ‘stretched’ version of the Dynamic with four seats and retractable undercarriage. It’s powered by a 115hp Rotax 914 fitted with a constant-speed propeller. The max weight is expected to be 850kg and the cruise speed around 115kt.
LX Aviation and the manufacturer, Aerospool, are working with the LAA for both aeroplanes to be approved as kits. in the UK prior to the kit being available mid 2019. www.lxaviation.co.uk
Hello
can you sell on WT10 Kit.
I am very interested to built it.
Thank you.
