6 December 2006
Pooleys Flight Equipment has teamed up with Flymap UK to integrate its famous Flight Guide into Flymap’s Moving Map system. This means that you can now have Pooley’s airfield plates available when you’re planning your flight in Flymap Win, as well as when you’re flying using the Pocket Flymap and L/XL nav system. Simply select the chosen airfield on-screen, and the Pooleys information will appear.
This is the first time that the Pooleys Guide has been available in electronic form.
Flymap systems are available from most good pilot shops.
