Russia announces Yak-152 trainer
Yak-152
The Yak-52 is a hugely popular aerobatic aircraft in the UK and now its replacement, the Yak-152, is under development by the Yakovlev Design Bureau. The aircraft is expected to make its first flight later this year.
The Russian Ministry of Defence has ordered 150 of the aircraft to replace the Yak-52 as the military’s training aircraft. Apparently more than 300 Yak-52s are still in service with the air force.
The Irkut Corporation, which will make the Yak-152 at its plant in East Siberia, says this about the aircraft.  [The] Yak-152 is designated for training in:
  • Piloting technique, including basic, advanced, and aerobatic pilotage
  • Navigation basics
  • Spin in and spin off techniques
  • Instrument en-route flight and landing approach using the airfield ILS
  • Group piloting at daytime, in VFR and over clouds.
Red V12 engine
The RED V12 turbodiesel engine to be fitted to the Yak-152.
The Yak-152 will be equipped with the German-made and designed 500hp RED A03T piston diesel engine already certified by EASA.
It will have an unpressurised ‘tandem’ cockpit with the forward seat designated for the trainee pilot, and the aft seat for an instructor although it can be flown solo from either seat. The avionics will be glass cockpit though no manufacturer has been named yet, and the Yak-152 will also have a SKS-94M ejection system.
Load limits are +9/-7 g solo, +8/-6 g two-up. Service life is not less than 10,000 hours, 30 years, and 30,000 landings. Oh, and hard points mean light arms and missiles can be carried.
Irkut Corporation
