12 May 2020
French startup company VoltAero has revealed the production design for its Cassio aircraft, powered by a hybrid-electric module.
It’s a radical design with a canard front wing, sleek fuselage and twin tail booms between which is the rear-facing pusher propeller.
VoltAero’s hybrid-electric power module has “a cluster” of electric motors with a high-performance internal combustion engine that serves as the range extender.
The powertrain currently is being validated on VoltAero’s Cassio 1 flight test aircraft based on a Cessna 337.
“The Cassio production design’s unveiling represents the latest step in our realistic and highly pragmatic creation of an all-new aircraft family,” said Jean Botti, VoltAero’s CEO and Chief Technical Officer.
“It benefits from our team’s unmatched experience in hybrid-electric aviation, as well as the ongoing full-scale flight testing that removes the risk as we move toward the production phase.”
VoltAero will offer Cassio in three versions:
The aircraft will be manufactured at a purpose-built final assembly line in the Nouvelle Aquitaine region of southwest France. Licensed production opportunities will be pursued in North America and Asia.
Initial deliveries are targeted for the end of 2022, beginning with the four-seat Cassio 330 version.
Possible uses of Cassio aircraft are private owners, air taxi/charter companies, commercial flights for point-to-point regional travel, and in various utility-category applications.
Cassio will be certified to Europe’s EASA CS23 certification specification as a single-engine, general aviation category aircraft.
Performance
Endurance 3.5 hours (extension possible to 5 hours)
Range: 800 miles
Cruise speed: 200 knots
Take-off/landing distance: less than 1,800 feet
Maximum takeoff weight: Under 2.5 metric tons (EASA CS23 certification)
Availability: 10 hours/day (equivalent to approximately eight rotations daily).
Although I do appreciate the extraordinary quietude of battery-driven vehicles, it is, nevertheless always a little mind-boggling that because the simple-minded don’t see a gas-guzzling engine in a vehicle (and are nieve enough not to know where electricity comes from, i.e., coal or oil or both) make the assumption that electricity, despite all it’s problems when operating in a motor vehicle, i.e., plane, train, whathaveyou, is in some magical way “cleaner” than a combustion technology that is tested, proven and more reliable (and a bit cheaper to boot).
The educated know electricity is cleaner. Very little is generated from oil and none from coal for the last 2 months in the UK. Source energy to wheel/prop using battery storage is about 35 to 40%, IC engines are 20 to 25% Hydrogen is even lower at 10 to 20%. Batteries are getting cheaper more power dense and faster charging . Once they reach 2.5kwhours per kilogram then liquid fuels are dead.
