ZeroAvia HyFlyer makes forced landing in field
ZeroAvia hydrogen
ZeroAvia proved its technology with a flight in a hydrogen fuel cell electric Piper Malibu at Cranfield in September. Photos: ZeroAvia
ZeroAvia’s hydrogen fuel cell powered Piper Malibus test aircraft made a forced landing just outside Cranfield Airport during a routine test flight on 29 April.
The Cranfield-based company said, “The aircraft landed normally on its wheels in a flat grass field and almost came to a stop, but was damaged as it caught the left main gear and wing in the uneven terrain at the end of the field at low speed.
“Everybody involved is safe, and without injury. The incident was immediately reported to the Air Accidents Investigation Branch (AAIB), and the Fire Service attended on the ground, as is the standard procedure.”
A spokesperson for ZeroAvia said that the flight conformed to the approved test route over the airport, and that the structural integrity of ZeroAvia systems was maintained throughout the incident sequence and there were no unintended hydrogen or electrical releases and no fire.
After the landing, the crew were able to safeguard the battery and safely release hydrogen from the onboard tanks, following ZeroAvia safety protocol. No fluid leaks were observed at the time and full data logs were preserved for use in an investigation.
“Following the flight test incident, ZeroAvia appointed a team of experts to conduct the internal investigation,” continued ZeroAvia’s statement.
“These individuals, led by Dominic Cheater, ZeroAvia’s Head of Airworthiness, are independent from the design and operation of the HyFlyer I programme.
“The investigation team will deliver a full review of the incident in collaboration with the UK’s AAIB, in-line with industry best practices and procedures. It will investigate the technical and operational events of the incident, identify its root causes, and ensure we learn from them. The process is already underway and we will share more once it is complete.”
ZeroAvia also confirmed that the incident will disrupt its planned six-seat HyFlyer demonstration programme that was coming to an end in the following weeks.
“However, we do not expect any negative impact on our commercial-intent HyFlyer 2 programme targeting 10-20 seat aircraft, or our large-engine development programme targeting 50+ seat aircraft.”
ZeroAvia
  • Ben says:
    “Aircraft has sustained some damage” appears something of an understatement, judging by the accompanying photograph! Always sad to see any aircraft suffer such damage, but especially so should the accident also impede an exciting development programme. Just glad that the crew escaped injury: it looked to have been a well-executed, textbook forced landing right up until the very last moments. Let’s hope that the AAIB investigation finds a cause wholly unrelated to the power source.
