UK's Vertical VX4 eVTOL flies outside Kemble circuit for first time
+VIDEO Vertical Aerospace says it has made European aviation history with the first-ever piloted wingborne flight of a winged electric vertical take-off and landing (eVTOL) aircraft in open airspace.
The flight of the VX4 prototype, piloted by Chief Test Pilot Si Davies, saw the aircraft take-off, fly and land like a conventional aircraft, with lift generated by the wing.
The VX4 left the circuit at Cotswold Airport (Kemble) for the first time witnessed by FLYER’s Jonny Salmon who happened to be close by.
The UK Civil Aviation Authority (CAA) approved the flight through open airspace at Cotswold Airport, the UK’s largest private airport, by extending Vertical’s Permit to Fly.
Vertical VX4 eVTOL leaves Kemble circuit for the first time
Chief Test Pilot, Simon Davies, said, “Taking the aircraft beyond the airfield and cruising over the Cotswolds for the first time was truly special and a career highlight for me.
“Our performance predictions were absolutely spot on, and the aircraft took off as a natural extension of all the ground tests and preparation we’ve done.
“There are aircraft which are safe and capable but not always enjoyable to fly. The VX4 was not only safe but was an absolute pleasure. It is responsive, smooth, simple to operate and the sound level from the propellers is quiet and pleasant in the cockpit.
“An honour to fly, and a real testament to the incredible team behind it.”
Vertical is currently the only company in the world flying a piloted winged eVTOL prototype that’s been developed under a Design Organisation Approval (DOA) from the CAA – a DOA is required to hold a Type Certificate, required for commercial passenger operations.
The CAA is working closely with the European Union Aviation Safety Agency (EASA) for their concurrent validation and certifying the VX4 to the highest safety standards required for commercial use.
Cockpit of Vertical VX4 during the flight
Stuart Simpson, CEO of Vertical Aerospace, said, “Achieving piloted wingborne flight in open airspace under the oversight of the UK CAA is an important moment in our certification journey.
“Operating under the UK’s rigorous regulatory framework means we share the burden of safety with our regulator – every step must be approved, and that’s by design. It amounts to a mini certification of our prototype and gives us a clearer, faster path to type certification.
“Our decision to put a pilot into the VX4 early was deliberate – real-world piloted flight delivers insights no simulation can. This milestone proves the capability of the aircraft and the maturity of our programme as we move toward commercial operations.”
Vertical is backed by UK government investment through the Aerospace Technology Institute and the Future Flight Challenge.
UK Secretary of State for Business and Trade, Jonathan Reynolds, added, “This is a fantastic milestone for Vertical and for the UK’s world-class aerospace sector. Breakthroughs like this show how government and business can work together to keep the UK at the cutting edge of innovation.”
In Phase 3 of testing – wingborne flight – the VX4 operates like a conventional aircraft using lift generated by its wings, rather than relying solely on rotor thrust. This low-power, quiet, and range-efficient mode of flight is key to making electric air travel practical, scalable, and economically viable.
During the wingborne flight phase, the VX4 will reach speeds of up to 150 mph (120 knots) and altitudes close to 2,000 ft under real-world conditions. Engineers captured more than 30,000 in-flight data parameters, confirming the aircraft performed exceptionally across stability, control, and energy usage.
Vertical Aerospace
