Thielert gains EASA STC for SR22
Buried towards the end of an otherwise dull financial press release, Thielert let slip that it has been awarded an EASA STC for the retrofit of its <a href=’http://www.centurion-engines.com/ ‘ target=’_blank’>Centurion 4</a> into the Cirrus SR22. The Centurion 4 is a V8 350hp engine that runs on Jet A1.
It is however significantly heavier than the IO-550 usually found in the SR22. Thielert’s website suggests that the company is working on STCs for retrofit into Cessna 414, 421, and 340 twins and the C206 single. A Beech Duke is already flying in Germany with a pair of Centurion 4s.
German press reports are suggesting that the SR22 with Centurion 4 will debut at Aero 07 in April.
