AvMap launches EngiBOX EMS
AvMap, the Italian manufacturer of avionic instruments, has launched EngiBOX, the engine monitor for Rotax aircraft engines, at AERO Friedrichshafen.
Fitting in a standard 79.5mm (3 1/8in) panel hole, EngiBOX is an ultralight (250g) and compact Engine Monitoring System (EMS) displaying the engine parameters with an update rate of five times per second and recording 160 hours of data in the internal memory.
EngiBOX displays: exhaust gas temperature, revolutions per minute, manifold pressure, oil pressure, oil / air temperature, and the cylinder head temperature/coolant temperature.
More information can be found at <a href=’http://avionics.avmap.it/’ target=’_blank’>avionics.avmap.it</a>.
