James Weiss puts his head above the parapet and gives his take on just what makes a good pilot
9 October 2025
What makes a good pilot? Handling skills? Radio confidence? Unflappable personality? Checklist Charlie? Or just someone who oozes competence?
Pilot James Weiss, a member of the American Experimental Aircraft Association (EAA) decided to get a bit more objective. He analysed aircraft accident reports, listened to safety and incident briefings, then came up with what he thinks are the characteristics embodied in a good pilot.
James writes in a column for the EAA, “The keyword that I will focus on is diligence. A good pilot is diligent.”
James starts right at the beginning with a pre-flight checklist with the mnemonic IMSAFE: Illness, Medication, Stress, Alcohol, Fatigue, Emotion.
“If the answer to any of these last four questions is YES, then maybe today is a good day to skip flying,” says James and he cites one particular accident.
In 2006, a helicopter training company lost a student and an R22 helicopter when the student on a solo flight crashed. The student said on the radio, “I can’t take it,” as he nosed-over and flew the aircraft into the ground. The student had broken up with his girlfriend the day before the flight.
If you answered ‘yes’ to any of these questions, you probably should not fly.
Hint: There is an AD for Ameri-King Corp emergency locator transmitters (ELTs). This is an old AD, but it is getting new attention. The AD covers Ameri-King models in the AK-450 series; as well as the AK-451 series. These ELTs MUST be checked for discrepancies and verifications.
It is a really good idea to check the ATIS (Automatic Terminal Information Service) before you push the aeroplane out of the hangar, or some other recognised source of weather info.
Look, two 220lb men in a Cessna 152 (100hp) may not be a good fit for a warm afternoon’s flight, especially in high humidity. Exactly how long is that runway you plan to use?
Even if you plan a VFR ride in good Wx, you should tell someone what you are doing.
How sharp are your skills?
You need to decide before you advance the throttle: What if you lose power on take-off? What are you going to do?
Point: Often the best course of action in loss of power on take-off is to land straight ahead, even if that means hitting trees.
Attempting to turn back to the runway, especially at low altitude, nearly always results in a stall/spin/crash. Don’t be that guy.
Point: You are not flying back from a secret mission to Germany where you must cross the Channel to get the secret codes back to England. Too often, pilots fly past alternate airports to ‘get home’.
A diligent pilot takes the effort to be constantly aware of his/her surroundings. Are you looking for a farm, or meadow, or straight road in case you need to make an emergency landing?
Only training can suppress the instinctive panic when bad things happen:
Turning around or going to an alternate airport is best. Summer thunderstorms can be deadly.
A good pilot is always looking for, or is aware of, alternate airports and/or landing sites. It is just good practice. After a while, it becomes second nature.
Trying to look good for your buddies (or passengers) is not worth it.
A diligent pilot takes inventory of his/her personal condition, his/her current skills, the material state of his/her aircraft, and the status of the weather BEFORE he/she engages the starter.
The diligent pilot uses every resource (CRM) at his/her disposal.
The diligent pilot has exceptional situational awareness, and is (mentally) prepared when bad stuff happens, or when other pilots violate airspace and radio procedures.
Are you a diligent pilot? Do have fun. But be safe.
Just six of the 30-odd CAA Safety Sense leaflets
There are a host of pdf leaflets available free to download from the UK CAA, known as the Safety Sense series. They each cover one specific subject and are stuffed full of concise safety advice.
The leaflets are currently being revamped, one by one, to bring them up to date and easier to understand.
Click here to review the Safety Sense leaflets and download them individually.
