17 March 2014
Hartzell Propeller Inc. has announced two- and three-blade versions of its new swept-tip Trailblazer prop for experimental aircraft and a number of certificated aircraft models.
The new Hartzell Trailblazer swept-tip propellers are designed to maximize performance of the numerous aircraft, both certified and amateur built, specifically designed for bush and backcountry flying. The two-blade version is compatible with most Lycoming 360 and 390 series engines, with no restrictions.
The next-generation Advanced Structural Composite Hartzell Trailblazer swept-tip prop will be exhibited at Hartzell Propeller’s B-034/35 booth at the upcoming Sun ‘n Fun International Fly-In & Expo, April 1-6, and installed on a homebuilt Sportsman at Glasair Aviation’s outdoor static display MD-017B.
<a href=’http://hartzellprop.com’ target=’_blank’>hartzellprop.com</a>
